Human airway simulation from STL
    • dungnguyenxuan199566
      Hello everyone,
      Hope this post finds you all well.
      I am trying to simulate human airway by CFD model. The process I am doing is.
      1, Get the human airway model (STL file, the software I use for segmentation is only able to generate STL).
      2, Import the stl file in fluent mesh for watertight.
      However, I have problem in this step. Since the import file is STL, the whole airway model appears as a single object. Now, for fluid extraction and further steps, I need to define inlet regions.
      Does anyone have experience with this? Would you mind helping me with this topic?
      Thank you very much in advance!
      Duplicate
      /forum/forums/topic/inlet-generation-needed-human-airway-simulation-2/
  • The topic ‘Human airway simulation from STL’ is closed to new replies.
