September 29, 2023 at 4:51 pm
pv00170
SubscriberI am usisng and HPC to run Ansys fluent. I use a batch which opens the fluent journal.
Inside the journal is written:;Set the TUI version for Fluent/file/set-tui-version "22.2";Read the case. The default folder/file read-case URANS.cas.h5;Set Number of Iterations/solve/dual-time-iterate 10 30;Outputting solver performance data upon completion of the simulation;/parallel timer usage;Write out the simulation results./file write-case-data result.cas.h5;After computation, exit Fluent/exitEverything looks fine, but an error takes place/ I can read inside the error file
/opt/software/pkgs/ansys/2022r2-fluids_structs/ansys_inc/v222/fluent/fluent22.2.0/bin/fluent: line 2886: 1931186 Segmentation fault (core dumped) $NO_RUN $CORTEX_PRE $EXE -f $FLUENT_PROD $CX_FLAGS "$CX_FUNCTION"
and in the output file, at the end
outletinletgeom_surfaceinterior-geom_surfaceatmfluid-geom_surfaceparallel,Done.Illegitimate input at /Report; PPTRootTemplateGuidIllegitimate input at /Report/ReportItem; PPTSlideIllegitimate input at /Report/ReportItem; PPTSlideIllegitimate input at /Report/ReportItem; PPTSlide>adjoint/ parallel/ server/define/ parametric-study/ solve/display/ plot/ surface/exit preferences/ views/file/ print-license-usagemesh/ report/>I dont know which PPTSlide is mentioning....What can I do? -
October 2, 2023 at 2:41 pm
Federico
Ansys EmployeeHello,
what is the command you are using to run Fluent?
Do you have any report definitions set up in your case file?
October 3, 2023 at 7:20 am
pv00170
SubscriberPlease find the reply attached.
October 3, 2023 at 7:19 am
pv00170
SubscriberHi Federico,
So the following Batch opens the Fluent journal#!/bin/bash Before it was #!/bin/sh hope nothing changed#SBATCH --partition=shared#SBATCH --job-name="cubeRANS"#SBATCH --nodes=1#SBATCH --ntasks-per-node=20#SBATCH --time=01:00:00#SBATCH --mem=60G#SBATCH --output=fltest.out#SBATCH -e fltest.err# # SBATCH --constraint=avx512 I have removed this since I think it does not exist anymoreml ansys/2022r2-fluids_structs# # MPI_EXEC=/opt/proprietary-apps/Intel_Parallel_Suite/xe_2019_5/compilers_and_libraries_2019.5.281/linux/mpi/intel64/bin/mpirun# # MPI_EXEC=/opt/software/pkgs/intel-compilers/2022.1.0/mpi/2021.6.0/bin/mpirun# # export MPI_EXEC=$(which mpirun) I have remove this since it is also old# # FLUENT_ARCH=lnamd64# # export FLUENT_ARCH I dont know if this is necesary/opt/software/pkgs/ansys/2022r2-fluids_structs/ansys_inc/v222/fluent/bin/fluent -g 2ddp -t 20 -i AnsysJournal.jou# # fluent -g 2ddp -t 20 -i AnsysJournal.jou If I use this line is the same as the previous one, isn't it?Which launches Fluent Journal with:
/file/set-tui-version 22.2 I have deleted this line, since nothing changes/file read-case URANS.cas.h5/file read-data URANS.cas.h5/file/confirm-overwrite? no/solve/dual-time-iterate 10 30 This is the point where it collapses/file/write-case Results.cas.h5/file/write-data Results.dat.h5exityesI don’t think the problem is related with the PPTSlide as I could run it using Fluent Wo
rkbench.
Yes, I am using Named Expressions and Report Definitions which are used for OUTPUT files.Seems like the program loads everything but then just stops. The error is still:
/opt/software/pkgs/ansys/2022r2-fluids_structs/ansys_inc/v222/fluent/fluent22.2.0/bin/fluent: line 2886: 387716 Segmentation fault (core dumped) $NO_RUN $CORTEX_PRE $EXE -f $FLUENT_PROD $CX_FLAGS “$CX_FUNCTION”
October 4, 2023 at 12:51 pm
Federico
Ansys EmployeeI believe this error is related to a graphical issue. Are you connecting remotely to a machine?
Also, not related to the error but in this line: /opt/software/pkgs/ansys/2022r2-fluids_structs/ansys_inc/v222/fluent/bin/fluent -g 2ddp -t 20 -i AnsysJournal.jou
try removing the space after -t to make use of the 20 nodes. It should read -t20.
October 4, 2023 at 1:15 pm
pv00170
SubscriberYes, I am accessing remotely using MobaXterm (that works with Putty)
Do you think the problem could be related with any of these two of the Batch?Since I am not using the constraint nor the mpirun
# # SBATCH –constraint=avx512ps: I have changed the -t20
October 4, 2023 at 1:39 pm
Federico
Ansys EmployeeEnsure that X11 forwarding is enabled. If accessing through Putty, under the menu 'Connection'->'SSH'->'X11' and tick to enable.
October 4, 2023 at 1:46 pm
pv00170
SubscriberYes, the X11 forwarding is enabled.
October 3, 2023 at 7:36 am
pv00170
SubscriberWhen I try to run it using PyFluent (script) instead of the HPC (Sbatch + script) it works well.
The pyFluent script is similar:
import ansys.fluent.core as pyfluentsolver = pyfluent.launch_fluent(precision=”double”, version=”2d”, processor_count=6, mode=”solver”)solver.tui.file.read_case(‘URANS.cas.h5’)solver.tui.file.read_data(‘URANS.dat.h5’)solver.tui.define.models.unsteady_2nd_order(“yes”)solver.tui.solve.dual_time_iterate(1, 2)solver.tui.file.write_case(‘Results.cas.h5’, overwrite=True)solver.tui.file.write_data(‘Results.dat.h5’, overwrite=True)print(“Done!”)The only difference is that HPC fails to compile whereas pyFluent works.
October 4, 2023 at 2:38 pm
Federico
Ansys EmployeeCan you try this?
You will need to have a graphics node with a certified, professional graphics card with the latest driver installed on the remote machine.
On the graphics node, you will then be able to launch Fluent or any Ansys application interactively. You will also need to use one of the Remote Display tools that Ansys supports. Please see below for more information about Remote Display and Graphics
Requirements.
Remote Display Requirements
October 4, 2023 at 3:10 pm
pv00170
Subscriber.
October 6, 2023 at 9:58 am
pv00170
SubscriberThank you, now it is solved!
- The topic ‘HPC – Fluent error’ is closed to new replies.
4914
1608
1386
1242
