May 24, 2023 at 11:06 pm
freud farid
Subscriberi need to validate this benchmark "Large deflection of curved cantibver under nonconservative tangential end load" , as show in image bellow , the force R is nonconservative load that mean the force R remains normal to the mid-axis of the beam during deformation
i need way to apply this kind of force in ansys ?
May 24, 2023 at 11:33 pm
peteroznewman
SubscriberHere is the Ansys Help entry:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/ans_elem/Hlp_E_FOLLW201.html
Here is an old discussion:
/forum/forums/topic/how-to-setup-a-follower-force-for-a-cantilever-beam/
May 25, 2023 at 12:05 pm
freud farid
Subscriberthis link not open
for the discussion , i have already read it , unfortunately It is useless
There will remain a problem that needs to be answered by Ansys
May 25, 2023 at 1:40 pm
peteroznewman
SubscriberFirst open Ansys Help.
Copy the URL above and paste it into the Address bar of the browser showing Ansys Help.
It will open.
May 25, 2023 at 2:44 pm
freud farid
Subscriberhi Erik Kostson
how you get this information in image ? How can I access to switch between elements availables
how i can choose or apply follw201 element ?
but I don't get the same results as reference and analytical result
May 25, 2023 at 4:33 pm
ErKo
Ansys EmployeeHi
Q: how you get this information in image ?
Go to Solution in the mechaniacl tree, right mouse button click and choose Worksheet Res. Summary (see below).
Q: how i can choose or apply follw201 element ?
As I said when we apply a force in mechanical on a line body (which is meshed with beam elements), automatically the follw201 elements are created by Mechanical and used, hence follower effects are considered.
All the best
Erik
May 30, 2023 at 2:08 pm
freud farid
SubscriberIt still gives me either beam188 when i use line sketch or solid186 when i use solid
I don't know where the problem is ?
i find extension in site for applaying 'follower load' but i didn't know how to apply it
How do I contact you privately?
May 31, 2023 at 1:20 am
peteroznewman
Subscriber-
May 31, 2023 at 11:45 am
ErKo
Ansys EmployeeIt is because the native force object inside mech., that generates the folw201 elements in the ds.dat file, uses keyoption(1)=1 – so not to update the direction.
We need a command to activate the update direction (below the type id is 2 for the follw201 element and typed id 1 for beam188):
All the best
Erik
June 1, 2023 at 10:20 am
freud farid
SubscriberErik
can you share in detail steps to do that ? i need to do this example in follower force for my master project , I desperately need help
May 31, 2023 at 12:43 pm
peteroznewman
SubscriberErik, I see what your original point was now that I opened the ds.dat input file and found an element type 201 for the follower element and the keyop,3,1,1 to keep the direction from changing!
/com,*********** Create Remote Point "Remote Force - Remote Point" ***********
*set,_npilot,74
_npilot50=_npilot
et,2,170
type,2
real,2
mat,2
keyo,2,2,1 ! don't fix pilot node
keyo,2,4,111111
tshape,pilo
en,38,74 ! create pilot node for rigid link
tshape
en,39,74,1
/com,*********** Define Vertex Force Using Follower Elements ***********
et,3,201
keyo,3,1,1 ! Keep the direction constant
keyo,3,2,1 ! Apply Forces only, not moment
mat,3
real,3
type,3
en,40,1
r,3
rmod,3,1,1.0, ! FX
mat,4
real,4
type,3
en,41,1
r,4
rmod,4,2,1.0, ! FY
mat,5
real,5
type,3
en,42,1
r,5
rmod,5,3,1.0, ! FZ
/gst,on,on
finiIn this model, the type ID for the FOLLW201 element is 3 so the Keyops are as shown below.
Thank you for the help Erik!
June 1, 2023 at 9:37 am
freud farid
Subscriberthank you for sharing the code , but when i use it not work and give error
please can you share the result of y displacement ?
can you show the detail by image how to apply follower load in example above ?
thank you
May 31, 2023 at 1:14 pm
ErKo
Ansys EmployeeAll the best Peter.
Erik
- The topic ‘how we can apply a follower load or nonconservative force in ansys ?’ is closed to new replies.
6024
