January 22, 2021 at 6:36 pm
AbdelrahmanSherif
SubscriberHi, I'm quite new to the whole simulation and ansys, I've been watching some tutorials on YouTube and I've had normal interface before I don't know what happened but it seems like my fluent is zoomed in, and I can't see the console under the graphics I just want to make things smaller
this is my current interface
January 25, 2021 at 4:50 amKeyur Kanade
Ansys EmployeeRight top corner - use Meshing Defaults. nnRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
January 25, 2021 at 6:29 pmAbdelrahmanSherif
Subscriberactually I did but it's still not zooming out I'm not just trying to get the console below the graphics but also want to zoom out, the text is so bignJanuary 26, 2021 at 10:14 amRob
Forum ModeratorText looks about right. Check screen resolution and scaling in the Win10 Display settings. nJanuary 27, 2021 at 2:53 amAbdelrahmanSherif
SubscriberI provided 2 pictures, first is mine and 2nd is how it used to be, it's not from windows, I don't know what happened but I'm even facing problem seeing the console unless I move it up sometimes, sometimes I can't press calculate button unless I move the console next to it so it squeeze it more, something is quite wrong but I've no idea how it did happennJanuary 27, 2021 at 4:01 amYasserSelima
Subscriberin the top right corner, the icon that looks like the document ... click on it and select the view you like.nJanuary 28, 2021 at 2:23 amAbdelrahmanSherif
Subscriberthis doesnt zoom out I can't click on calculate or increase the number of iterations unless i bring the console up therenJanuary 28, 2021 at 11:29 amRob
Forum ModeratorYou're showing images of Fluent Meshing, there isn't an iterate button to bring up. Re the top menus in Fluent Meshing, the above tends to happen when the graphics resolution gets scrambled: you can try renaming the %appdata% file/folder that's linked to 2020R2.nJanuary 30, 2021 at 1:57 pmAbdelrahmanSherif
SubscriberViewing 8 reply threads- The topic ‘how to zoom out and have proper user interface’ is closed to new replies.
3587
1193
1086
1068
952
