February 28, 2017 at 7:57 am
Nikita
Ansys EmployeeHow can I import and use STL files with ANSYS Simulation products?Â
July 21, 2017 at 6:17 pm
pgl
Ansys EmployeeThe best way to work with STL files is to import the STL file into ANSYS Spaceclaim and then convert into a CAD geometry file such a Parasolid. The CAD geometry can then be used by ANSYS Mechanical and other ANSYS simulation products.Â
Note that generally *.STL files are not able to capture geometry appropriately and ANSYS Spaceclaim helps to repair the .STL file if needed.
July 17, 2022 at 3:07 pm
Ankura
SubscriberIt is best to import STL files into ANSYS Spaceclaim and export them as CAD geometry files such as Parasolid files.It is the best way to do this task.
March 17, 2023 at 1:15 pm
Aras karimi
SubscriberHi dear friend
I have the XYZ coordinates of the points of a 3D geometry in the form of a text file.
I want to open this file in the Design Modeler to produce geometry for me, but I don't know how to do it.
Thanks for your help.
October 23, 2022 at 3:51 pm
Massimo Capoccia
SubscriberI would be grateful for your assistance on this occasion.
I have meshed a STL file in Ansys ICEM. It is a complex geometry. When I import the mesh in Fluent for CFD analysis, I keep receiving the same warning message despite my attempts to review the mesh in ICEM. Here is the warning message:
Building...
mesh
Error: Build_Grid: no faces in case file.
Clearing partially read grid.
Error: Build Grid: Aborted due to critical error.
Error Object: #f
Where am I going wrong?
I can share my file on a teams or zoom call in order to exchange an opinion and advice.
Kind Regards
Massimo Capoccia
January 30, 2023 at 9:47 am
Siddharth Verma
SubscriberTo import and use STL files with ANSYS Simulation products, follow these steps:
Start ANSYS Workbench.
Open the Geometry toolbar and select "Import".
Choose "STL" as the file type.
Navigate to the location where the STL file is saved and select it.
Define the import options and click "OK".
In the Model Tree, right-click the imported geometry and select "Create Surface Body".
The imported STL file is now ready for use in ANSYS Simulation products.
Note: Some ANSYS products may require additional steps to convert the imported STL geometry into a simulation-ready format.
- The topic ‘How to work with STL file?’ is closed to new replies.
