March 3, 2019 at 10:41 am
Huan19Han
SubscriberHello,
I have a model, a MDF (Medium-density fibreboard) plate in ANSYS workbench.
As you can see, its density varies along the z direction (thickness direction).Â
I know I can divide the plate into some thinner plate with constant density but I use this plate for the transient analysis and the plate is covered with some (more than 10) absorptions layers. For each absorptions layer, there is an APDL-snippet to define the damping coefficient.
If I do so, the absorptions layers should also be divided into some thinner layers. It will be a complex model.
How can I vary the density?
Thanks a lot!
March 5, 2019 at 12:12 am
March 5, 2019 at 6:25 pm
Huan19Han
SubscriberHello Sandeep,
thank you very much!
Regard,
Huan
March 6, 2019 at 9:15 pm
- The topic ‘How to vary density along one axis in Ansys Workbench’ is closed to new replies.
1885
1403
1262
