March 4, 2025 at 11:22 am
muhammadaziz.sarwar
SubscriberI am working on composite pipe haveing steel wires as reinforcment and rubber.Query1: I want to simulate only plastic deformation .I tried to use voce law but it activates at certain increasd pressure. Not at low pressure where we have less stresses developed .I tried with prestress equal to yield stress so voce law activates but a lot more deformation observed.Suggest me any material which gives me directly plastic propety of steel.I have uniaxial experimental data of my materials.Query 2:I want to apply working pressure and burst pressure in mechanical apdl ? is it possible to apply in working pressure and burst pressure because working pressure involves pressure applied for soem minutes and burst pressure includes pressure applied in steps then keep applying each pressure for some time ?
March 10, 2025 at 1:03 pm
John Doyle
Ansys EmployeeYou might consider using reinforcing elements REINF264. Ansys supports two methods for modeling reinforcing cables or fibers: Discrete Reinforcing and Smeared Reinforcing . Refer to Section 5.5. Reinforcing Elements and REINF264 of the MAPDL Elements Reference Manual for details. You can also use INISTATE to introduce prestressed condition in the rebar. Loads and BCs can also be applied in MAPDL as functions of time.
If you are defining time dependent loads, I assume you need rate dependent material properties. Without rate dependency defined in the materials, your time dependent load history will not produce any relaxation or creep. A rate dependent material response can be included in both the hyperelastic material (for the base rubber) and also in the reinforcement, for the steel reinforcement. The material model combinations needed depends highly on the test data that you have available and the complexity of the load history. I would start with a review of the Viscoelastic Prony Series (superimposed on a rate independent hyperelastic material) for the rubber material relaxation (if necessary) and a rate dependent creep material model (superimposed on a metal plasticity) for the rebar. See MAPDL Material Combinations of the MAPDL Material Reference Guide, for more details.
March 12, 2025 at 3:19 pm
muhammadaziz.sarwar
SubscriberThanks for detailed response.Okay thank you so much for your reposne i am using smeared reinforcment could you please tell me selecting base elements are not enough if we want to reinforce full base element with smeared reinforcment for 3d base element beacuse i think.i am using element face,but i am not sure my full base element is reinforce as i am recieving less strong base element against the material property of reinforcemnt please explain about equivalent thickness and role of element face.. If we want to reinforce full base element for example 1mm thickness how many layers or role of area of fiber and distance between themREINF265. For material properties ..I am confused to use voce law ...for elastic results..and could you share any documnet when materail hardening parameters starts to work for example elastic to plastic transition ? could we control that elastic to plastic transition to check desired output.Thanks again for your response.
July 25, 2025 at 3:51 am
manuelmassey632
SubscriberYou may want to consider using the REINF264 element for modeling reinforcement. ANSYS-stickman hook offers two primary approaches for simulating reinforcing fibers or cables: Discrete Reinforcement and Smeared Reinforcement. For detailed information on these methods and the REINF264 element, refer to Section 5.5 (Reinforcing Elements) in the MAPDL Elements Reference Manual.
Additionally, you can use the INISTATE command to define initial stress states, such as introducing pre-stress into the reinforcing steel.
Furthermore, both loads and boundary conditions in MAPDL can be defined as functions of time, allowing you to simulate time-dependent loading such as gradual pressure application or hold phases.
March 6, 2026 at 3:49 am
snowballs058
SubscriberThanks for the detailed information about the composite pipe structure. For Query 1, instead of trying to force laws like Voce, use the Multilinear Isotropic Hardening (MISO) model to directly load the experimental uniaxial data into the APDL this is the shortest way to closely approximate reality without simulation errors. I practiced my ability to interpret variables and react accurately through the Drift Boss game to stay alert when faced with complex stress diagrams. For Query 2, dividing the Load Steps (LSWRITE) combined with the KBC, 1 command for burst pressure and KBC, 0 for working pressure is entirely feasible for controlling the pressure holding time.
6309
