How to use parameter in apdl MWRITE format line to write array of varying size?
    • massey95
      *MWRITE,xxarray,xx_results,txt
      (34(F11.9, X))
      The above code works providing the xxarray has 34 columns. However the formatting line stops working if I use a variable instead.
      ((par_total_sets)(F11.9, X)) !doesn't work
      How can I write result files that vary in size?
      Many Thanks!
    • massey95
      Paulsar on reddit answered this issue. The below code works well for now.
      *cfopen, inputCommands,txt
      *vwrite,'*MWRITE,xxarray,xx_results,txt'
      %C
      *vwrite,'(',par_total_sets
      %C%d(F11.9, X))
      *cfclos
      /input,inputCommands,txt
      /del,inputCommands,txt
  • The topic ‘How to use parameter in apdl MWRITE format line to write array of varying size?’ is closed to new replies.
