How to use more than two temperature ranges of Chemkin thermodynamic data in Fluent
    • kzqing
      I am trying to simulate air dissociation effect in hypersonic flow. I import Chemkin mechanism into Fluent. For the thermodynamic data, when I just use two temperature ranges, it works fine, the two temperature range format is as followings:
      However when I tried to use three temperature ranges:
      Fluent gives me Error: Invalid THERMO data at line no. 18.n.
      I checked the "Chemkin-Pro Input Manual", it says "using more than two temperature ranges", the format should be like this. Is it that Fluent does not support more than two temperature ranges?
      Could someone help me here?
      Thank you,
      Qing
    • kzqing
      Hello! Are there anyone who can help me with my question?
      It seems that after changing from "ANSYS customer portal support" to this "student community", it becomes quite difficult to get support from ANSYS support engineers.
    • DrAmine
      I will check and come back to you
    • DrAmine
      Which mechanism are you trying to use?
    • kzqing
      I use my own defined mechanism. It looks like this:
      REACTIONS
      O2+M<=>2O+M                              3.610E+18   -1.000  117968.40
         REV/ 3.01E+15    -0.500    0.00/
      O2/ 9.00/ N2/2.00/ O/ 25.00/ N/ 1.00/ NO/ 1.00/
      end
      Thanks,
      Qinq
    • DrAmine
      Let me check and come back to you. I will update you asap.
    • kzqing
      Hello Amine,
      Have you got any update? My research can't get further because of the problem. Hope you can help me soon.
      Thanks,
      Qing
    • DrAmine
      I will update you soon.
    • kzqing
      Hello Amine,
      May I ask if you find a solution yet?
      Thanks,
    • DrAmine
      No still working on that. Might take some time.
    • DrAmine
      The problem has been resolved.
Viewing 10 reply threads
  • The topic ‘How to use more than two temperature ranges of Chemkin thermodynamic data in Fluent’ is closed to new replies.
