Photonics
Photonics
How to use lumerical varFDTD to run simulation with multiple materials
    • LittleMonster
      Hi Lumerical Support Team,nCurrently, I am trying to use varFDTD to run 2.5D simulation with multiple materials. I am not sure I set everything correct. Can you please help take a look at the test.lms file. It is a silicon Y-branch, but in the middle region, there are few different materials. I put the green cross in the input port. But how to deal with the materials in the middle region?nMany thanks.n
    • Guilin Sun
      I guess that you mean vertically (along z direction), there are different materials, eg, the Y branch is silicon, but in between the waveguides of the Y branch, it has other different materials. Since the VarFDTD method uses the waveguide mode to get the effective index of all other regions, it is ok to place the green cross in the silicon waveguide. The effective index at all other locations will be calculated automatically. You can refer this ring resonator example,https://support.lumerical.com/hc/en-us/articles/360042800293-Ring-resonator-getting-started-Design-and-initial-simulationthis file ring_resonator.lms has ring and bus waveguides that stand up. However the other region (substrate,air) will be able to get the effective index for the simulation. The fundamental principle can be found herehttps://support.lumerical.com/hc/en-us/articles/360034917213-MODE-2-5D-varFDTD-solver-introduction-
  • The topic ‘How to use lumerical varFDTD to run simulation with multiple materials’ is closed to new replies.
