TAGGED: inverse-design, lumopt, topology-optimization
September 2, 2024 at 7:45 am
2200453024
SubscriberHi !
In topology optimization, it's possible to use a custom geometric structure as the initial design. I referred to the settings in the cases "y_splitter_topology" and "CWDM_splitter_1310_4ch_2D_TE_topology":
- Placed the custom initial structure in the "initial_guess" structure group.
- Set the
paramsparameter of the geometry toNone.
However, when running the simulation, I encountered the following error:
UserWarning: Project file structure 'initial_guess' reports 1 parameter where expected 5929. This can occur when the number of x, y coordinates specified to LumOpt do not match the dimensions of the FDTD grid. Try using similar or divisible delta values (size of a pixel) across all the axes.
In my FDTD settings,
mesh accuracy = 3, and no additional mesh was added to the optimization region. It seems to match the settings in the examples, but I can't figure out why the error occurs. Are there any other details that I might have overlooked? -
September 5, 2024 at 7:05 am
Niki Papachristou
Forum ModeratorHi Jiahao,
Thank you for reaching out to us and asking this question! May I ask you whether you have come across this post: Topology inverse design mesh interpolation. One of our users have a similar question and a colleage of mine has provided a detailed response there.
Let me know if that covered you or you would like further assistance.
Kind Regards,
Niki
December 31, 2025 at 9:57 am
22B921023
SubscriberI am encountering the same issue. I reviewed the post you mentioned, but it didn't resolve the problem, and it doesn't seem to be the real cause. How should I go about solving this?
September 6, 2024 at 6:46 am
2200453024
SubscriberThank you for your response, Niki.
I have read through the post you shared, but I still don't know how to solve my problem.
In my lsf file, the opt_fields is a square with a size of 1.52e-6, and the FDTD region has mesh accuracy set to 3. The opt_fields does not have additional grid settings.
In the Python code, I set:
size_x = 1520
x_points = int(size_x / 20) + 1
x_pos = np.linspace(-size_x / 2 * 1e-9, size_x / 2 * 1e-9, x_points)
(the same as y)I'm not sure if this setup is correct. The example seems to be configured similarly, but I don't understand why it 'reports 1 parameter.' Even when I change the shape of the geometry or grid size, it still reports only 1 parameter.
