August 21, 2023 at 10:12 pm
Yushu Zhao
SubscriberHello:
I am working on using HFSS to simulate the Q factor of a specific structure. The version of the HFSS I am using is 2022 R2
My setup is :
- change the solution type to HFSS, Network analysis, Modal, auto open ragion.
- I cover a layer of perfect E on the input/ and output terminal of my structure
- define the wave port on the face of the input/ and output terminal of my structure
- in analysis I selct broadand, and add a frequency sweep.Â
- run the simulation and export the Y parameter.
- The formula to calulate the Q factor that I used is im(1/Y11)/Re(1/Y11)
Now, the Q factor graph that I get is wired since I got some very high speck.Â
August 22, 2023 at 7:47 am
dushyant.marathe
Ansys EmployeeHello Yushu Zhao,
Thanks for posting your query on Ansys Learning Forum. I could see that mentioned setup steps and expression are correct to compute the quality factor of the structure.
However, I suspect issue with some settings especially Port creation. This will have to check with the actual model. If you have access to Ansys Techical support, please raise a service ticket and support engineer will connect you to resolve the issue.
Thanks.
August 23, 2023 at 3:50 am
Yushu Zhao
SubscriberCould you please provide me with the way to access the ansys technical support?
August 23, 2023 at 6:21 am
dushyant.marathe
Ansys EmployeeHi Yushu,
Please get in touch with your Ansys account manager. He will guide you on how to request access to Ansys Technical support.
Thanks,
- The topic ‘How to use HFSS to simulate the Q factor of a inductor structure’ is closed to new replies.
5809
