November 15, 2021 at 11:19 am
湯岳霖
SubscriberNovember 16, 2021 at 5:45 amSahil Sura
Ansys EmployeeHello Seems the conditions like the key slot makes the geometry not support the cylindrical support to be scoped to the respective geometry. You might try removing the key slot and then scope the cylindrical support.
Even if cylindrical support was used, radial and tangential motions would be fixed allowing the motion along axial direction. You can replicate the same by creating a local cylindrical coordinate system and adding displacements scoping to the coordinate system with the free motion scoped to respective axis keeping other axes constrained.
Cylindrical Support (ansys.com)
Displacement (ansys.com)
Hope that helps!
Thanks Sahil
Viewing 1 reply thread- The topic ‘How to use Cylindrical Support in this case’ is closed to new replies.
5669
1890
1419
1304
