December 29, 2024 at 12:39 pm
fdtsaid
SubscriberSome predefined operator can be used as input operator of iterator. Such as the following exampleÂÂfunction test(a,b: int8 ^ 3) returns (c: int8 ^ 3)c = (map $+$ << 3 >>) (a, b);ÂBut I am trying to figure out how to use$@$as input operator correctly. In the following program: ÂÂfunction mapOp(arr1,arr2: int8 ^ 2 ^ 3) returns (oarr: int8 ^ 4 ^ 3)letoarr = (map $@$ <<3>>) (arr1,arr2);telÂThe intention of the above program is to concatenate each element of typeint8^2in arr1 and arr2 to value of typeint8^4. But I got the following error:Prefix operator $@$ expects 2 size parameters but is here used with 0ÂHow to use$@$as input operator of iterator in a correct way? -
January 3, 2025 at 1:38 pm
Benjamin Descorps
Ansys EmployeeHello,
It is not possible to use directly the concatenation operator through an iterator. But you can through an intermediate operator. Here is the piece of code that should match your need:
function mapOp(arr1,arr2: int8 ^ 2 ^ 3) returns (oarr: int8 ^ 4 ^ 3)Â Â Â oarr = (map Op <<3>>)(arr1, arr2);Âfunction #pragma kcg expand #end Op(i1, i2 : int8 ^2) returns (o : int8 ^4)Â Â Â o = i1 @ i2;ÂHope this helps,ÂBenjamin -
January 3, 2025 at 2:04 pm
fdtsaid
SubscriberThe solution is very inspired, thank you!
