June 13, 2019 at 3:11 pm
Avinash114
SubscriberAfter uninstalling the ANSYS programs from the computer, I am still not able to delete the ANSYS Inc. folder from Program Files-- My Computer .
I want to completely remove the ANSYS files from my device.
June 13, 2019 at 10:00 pm
tsiriaks
Ansys Employeeopen up elevated CMD Prompt , right-click on CMD Prompt and 'run as administrator' , then issue the following commands. Make sure you change your install path accordingly
"C:Program FilesAnsys IncShared FilesLicensingwinx64ansysli_server" -k stop
"C:Program FilesAnsys IncShared FilesLicensingwinx64ansysli_server" -k uninstall
sc stop ANSYSLicensingTomcat
sc delete ANSYSLicensingTomcat
then, you should be able to delete the ANSYS Inc folder.
Thanks,
August 22, 2019 at 7:24 pm
Antang
SubscriberI'm not too familar with the command prompt but how do i do this if my first line of the prompt is "C:>" and my ansys is in that exact same folder destination. Also do I need to write that with the quotations?
August 22, 2019 at 7:59 pm
tsiriaks
Ansys EmployeePlease post the screenshots of your ANSYS directory.
It's ok if your first line has C:>
Yes, you need to include quotes
August 22, 2019 at 10:11 pm
Antang
SubscriberNevermind I think i got it thanks!
August 23, 2019 at 12:38 am
tsiriaks
Ansys Employeesounds good.
Thanks,
Win
September 2, 2020 at 6:11 am
Sadaf
SubscriberJanuary 28, 2021 at 6:17 amHesam062
SubscribernI also want to delete the Ansys folder completely after being uninstalled. I did what you mentioned but it still can not be removed. Is this issue related to Ansys license manager. Do I have to uninstall/delete Ansys license manage first? If so, please guide me.nThanks!nViewing 8 reply threads- The topic ‘How to uninstall ANSYS license manager’ is closed to new replies.
3712
1313
1163
1090
1014
