Photonics
Photonics
How to tilting the model
    • Serein
      How can I set up the model structure in FDTD so that it is tilted like in the diagram? I have searched through all the structure options but couldn't find a "tilt" setting. If it's possible to do this using a script, please also let me know how to write it. Thank you!
    • Guilin Sun
      You can use structure group to set up the geometry without tilt, and rotate the structure group as needed:
      Make sure the titled geometry is what you need, by specifying correct axes and angles.
      • Serein
        Got it, thank you very much.
