September 25, 2024 at 9:59 am
hao1996
SubscriberWhen I use an imported mesh from Hypermesh in Ansys Mechnical, the imported geometries are set as one solidbody like the following picture:
When I need to set one of these bodies to rigid body, the error of "All bodies under this part must have the same setting for stiffness behavior" occurs. So, how can I split these bodies into seperate ones?
September 30, 2024 at 7:45 am
ashish.khemka
Forum ModeratorHello,
You have asked same query here: How to split solid bodies? - Ansys Learning Forum | Ansys Innovation Space
I will close this thread.
Ashish Khemka
- The topic ‘How to split solid bodies?’ is closed to new replies.
