TAGGED: ansys-mechanical, ansys-student, designmodeler
December 11, 2020 at 5:20 am
as880
SubscriberI would like to split this body into multiple bodies that are attached together. I can see the boundaries from this top view, but from bottom all 3 surfaces are flush together so i think ansys thinks of it as a single body. Please outline the exact steps ill need to follow as I am just starting out on ansys. Thank You
December 11, 2020 at 3:12 pmRahul Kumbhar
Ansys EmployeeHi ArrayYou can use Split tool under Design tab and select the stepped face to split the body.n
n
January 20, 2021 at 9:27 amAniket Chavan
Forum Moderator,Can you please post your response to 's solution and why it did not answer your question?n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnViewing 2 reply threads- The topic ‘How to split bodies in spaceclaim’ is closed to new replies.
5264
1859
1398
1256
