April 11, 2019 at 7:06 pm
liweiyi
SubscriberHi,
I'm using fluent mesh tool. It would be nice for my project if I can spilt a single domain into two parts and mesh them with different mesh methods. (Still the two parts are connected.) I wonder if there is a way I can do that?
Thanks
Weiyi
April 12, 2019 at 11:11 am
peteroznewman
SubscriberIn SpaceClaim, you draw a line or curve on the face and that will split the face, or you can split the face with a plane. Similar methods apply in DesignModeler.
April 12, 2019 at 8:30 pm
liweiyi
SubscriberSo how can I do the similar thing in 3D with DesignModeler?Â
April 13, 2019 at 12:10 am
peteroznewman
SubscriberIn DM, it is called Face Split.
https://www.youtube.com/watch?v=2TR3EDFcdH0
If this post answers your questions, please mark it with Is Solution.
April 13, 2019 at 12:56 am
liweiyi
SubscriberThanks for your reply! In this way, I'm able to split a face into 2. But what I'm aiming is to apply different mesh to 2 parts of a 3D object. Here is the geometry. There is a single submerged square cylinder inside the channel. Ideally, I want to apply sweep meshing method to part 1 and part 2 separately. I wonder if it is possible with fluent meshing and DesignModeler.
April 13, 2019 at 3:03 am
peteroznewman
SubscriberYes, you slice the body into two bodies with a plane, then pick the two bodies and Form New Part to make a single part again. Each body can have its own mesh setting, but the nodes will be shared at the interface.
https://www.youtube.com/watch?v=IK2ssvjM0a4
April 15, 2019 at 4:44 am
liweiyi
SubscriberThanks!
- The topic ‘How to spilt a single domain into two parts and mesh them with different mesh methods’ is closed to new replies.
4162
1487
1318
1170
