How to specify the “signif” parameter of CQC command in Workbench Mechanical
July 15, 2024 at 2:30 pm
jean.collomb
SubscriberHi,
In Workbench Mechanical, I am doing spectrum analysis.
For each acceleration/freq. load, I specify CQC combinason, but I do not find how to specify the "signif" parameter.
Is there a way to specify this value for each load direction ?
Jean
July 16, 2024 at 3:19 pm
danielshaw
Ansys EmployeeAccess to the "signif" parameter in not exposed in the Mechanical UI. You need to specify it using the CQC command in a Command Object.
You cannot specify a different signfi per direction. It is one global setting.
- The topic ‘How to specify the “signif” parameter of CQC command in Workbench Mechanical’ is closed to new replies.
1343
1152
