July 5, 2024 at 11:29 am
matthew.crossley
SubscriberDear All,
I need to produce a series of flux density plots and compare them in a document. This means that I need the flux density scale to be identical for all the images, e.g. between 0 T and 2.4 T. Currently the scale changes based on the maximum and minimum flux density values in each individual flux density plot (the default situation). How can I specify this on MotorCAD?
Many Thanks, Matthew
July 9, 2024 at 9:06 pm
HDLI
Ansys EmployeeHello Matthew,
   In the FEA tab of MotorCAD, you could find Shading Range, please disable "Automatic" and then you can specify your own range.Â
HDLI
- The topic ‘How to specify the range of the scale for a MotorCAD FEA plot’ is closed to new replies.
1891
1419
