How to specify species/mass diffusivity in pdf mixture
    • roytorc
      I'm using flamelet model to generate PDF table. I would like to test the sensitivity of the system to species diffusivity. However, in pdf mixture menu, I can only found UDS diffuivity box. Could you please advise how can I modify species diffusivity or is the UDS diffusivity is applied to species (pdf mixture) as well?
    • DrAmine
      Not possible. Only transport properties like viscosity and thermal conductivity can be set. Check the manual.
    • roytorc
      Thank you for your reply. I found that turbulent diffusivity bases on turbulent viscosity and Schmidt number. Can I modify PDF Schmidt number in SST k-omega model to reflect my problem?
    • DrAmine
      Turb diffusivity is not what you asked for in the beginning.
      I won't mess with that turbulent stuff but you can adjust the turb. Schmidt number there.
  • The topic ‘How to specify species/mass diffusivity in pdf mixture’ is closed to new replies.
