How to specify in fluent expressions?
November 12, 2020 at 10:21 pm
unicrey
SubscriberI am trying to create a monitor report plot for average static pressure.nWhile creating the expression, this works -nAverage(StaticPressure,['plate']) where plate is named boundary.nHowever, I do not want the average over the whole plate. So I created a line 'platesmall'. When I try nAverage(StaticPressure,['platesmall']), it shows invalid location.nnplatesmall works great elsewere when I am creating plots etc. So how do I specify the location for averaging here.nnI tried to find documentation for this in the ANSYS User Guide but there was nothing in there about how to specify the . n -
November 13, 2020 at 12:02 pm
Forum ModeratorExpressions are an evolving feature at the moment. I'd suggest using an adaption register to separate out a few cells and report on those. A line doesn't technically exist for some of the reporting as it's not a geometry feature (ie it's not represented by the mesh). n -
November 16, 2020 at 10:05 pm
unicrey
SubscriberGot it. Thanks for your help.n -
April 16, 2021 at 9:43 pm
unicrey
SubscriberOkay, I had solved the earlier problem in a different way but coming back to expressions now, turns out cell registers don't work either. n'gradient_vof_refine' is a predefined cell register. I have also tried similarly with other cell registers I have defined.nnAverage(VelocityMagnitude,['gradient_vof_refine'],Weight = None) gives - nInvalid locations( gradient_vof_refine)nnAverage(VelocityMagnitude,[gradient_vof_refine],Weight = None) gives -nRuntimeError: Average: Argument 2 is invalidnnAverage(VelocityMagnitude,,Weight = None) gives -nSyntaxError: invalid syntaxnnI have tried other Weights as well. Shows similar errors.nIs there any other way to make this work?n -
April 17, 2021 at 2:19 am
YasserSelima
Subscriberlocation should be a boundary, not cell registrar ...n -
February 26, 2023 at 8:54 pm
ahmed ibrahim
Subscriberhow to define cell temperature in expression instead of average temperature
i know in udf is like (C_T(cell,thread)
Viewing 5 reply threads
- The topic ‘How to specify
in fluent expressions?’ is closed to new replies.
Ansys Innovation Space
1103
1063
1045
952
