June 24, 2020 at 11:43 pm
June 25, 2020 at 12:27 am
peteroznewman
SubscriberAre you trying to simulate an impact event? I see a ball some distance from a plate. That is not how you setup an impact simulation. Go back to CAD and place the ball tangent to the plate. Then in the simulation, assign it an initial velocity.
Delete the Directional Deformation.
Under Analysis Settings, Output Controls, you want 500 results before the End Time. The default is 20.
- The topic ‘How to solve the error when occurs in explicit dynamics analysis’ is closed to new replies.
1829
1387
1248
