March 22, 2023 at 11:43 pm
XianCheng Meng
SubscriberThis problem happened when I want to update or transfer geometry from 'Geometry' block to 'Maxwell 2D' block in workbench. The below figure show the error note.
However, this problem only happened when I enable parameters. If disable parameters, the third line 'Parameters' of block A and 'Parameter set' block will disappear, and I can update or transfer geometry. In addition, I use SOLIDWORKS to do parametric modeling, and reload the geometry in Workbench-Designmodeler. I tried to reInstall both ANSYS and ANSYS EM, even reInstalled Windows, it's not useful.
May 5, 2023 at 12:38 pm
Aniket Chavan
Forum ModeratorSo assuming you are using commercial/university license, as the solidworks interface is not supported with free student version, can you please check if small parametric cube/rectangle transfers well to DesignModeler and Mesh?
-Aniket
- The topic ‘How to solve ‘OnRefreshTransferData failed!’ issue?’ is closed to new replies.
5014
1683
1387
1248
