August 3, 2021 at 12:56 pm
Ceren
SubscriberHi,
When I try to run the CFX file, I face the error 'The ANSYS CFX solver has terminated without writing a results file.
Command on host laptop8h70vese exited with return code 0.' So, it cannot run. How can I fix this problem?
Many thanks.
August 3, 2021 at 6:27 pmSurya Deb
Ansys EmployeeHello,
Is there any other error/warning in your out file?
Did you try running it on any other system?
Regards SD
August 3, 2021 at 6:41 pmCeren
SubscriberI also received another errors ' Update failed for the solution component in CFX. The solver failed a non-zero exit code of: 2 ' and 'CFX_001 has terminated with errors.'
So, I cannot open the solution part of CFX.
Best regards Ceren
Viewing 2 reply threads- The topic ‘How to solve error in ANSYS CFX?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3887
1414
1241
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
