September 5, 2022 at 4:17 pm
September 12, 2022 at 1:01 pm
Yu Bi
Ansys EmployeeHi, those errors are caused by the imported geometry not matching the Aqwa requirements for model geometry. Please check in the SpaceClaim/Design Modeller if there are any overlapped surfaces, T-shape or X-shape cross-section junctions between surfaces. Also, if possible, try to use the SpaceClaim repair tool to repair your geometry, e.g. stitch the surfaces, check duplicates, repair curves, etc. I hope those will solve your problem. Â
- The topic ‘How to solve coincident nodes problem in ansys aqwa’ is closed to new replies.
