April 10, 2024 at 10:05 am
chen guohao
SubscriberHow to simulate the calculation in speos and how to arrange the plant lights to meet the required PPFD?
When I use speos, I find that I can only calculate lumens with light intensity sensor. Is there a corresponding simulation teaching process for calculating PPFD? -
April 11, 2024 at 1:10 pm
Thomas Martineau
Ansys EmployeeHello,
There is no easy answer to measure photons, but using a radiometric/spectral sensor, you can obtain a value in watts, then from this, knowing time you can find energy and then calculate the number of photons from the energy of a single of photon at a known wavelenght.
You can find help to setup a measure in the result at this adress : Making Measures Analysis
Best regards
April 12, 2024 at 1:18 am
chen guohao
SubscriberThank you for your help
- The topic ‘How to simulate PPFD in vertical farms’ is closed to new replies.
4838
1587
1386
1242
