How to simulate Ionic Wind in ANSYS Workbench?
    • Ammar676
      Hey everyone,
      Does anyone know how to simulate Ionic wind? I need recommendations on how to start and which analysis would be perfect for that topic.
      Thanks
    • Surya Deb
      You might want to take a look at Fluent's MHD module.
      I guess to simulate the ionic wind, you will also need to model the ions using DPM.
      Once MHD is activated, you should be able to provide electrical properties to DPM particles including charge density.
      This can be combined with other flow features.
      Regards SD
    • Ammar676
      Thank you so much for your time. However could you please elaborate on the MHD and DPM?
      I am still a beginner in ANSYS Fluent so I'd appreciate it if you can simplify it to me please.
      Best Regards
      Ammar
      DPM - Discrete Phase Model.
      MHD - Magnetohydrodynamics
      If you're not overly familiar with the software I suggest working through the tutorials: this is unlikely to be an easy project.
    • Ammar676
      Thanks Rob for your comment.
      Where can I find such tutorials?
      Click on "Help" in Fluent, there are some in the documentation along with videos on our YouTube channel (some linked from documentation).
    • Ammar676
      Is there any other way to simulate the ionic wind in a simpler form.
      If you reckon, can I do it on ANSYS Workbench?
      Break the problem down into parts: what is the ionic wind? If you can define that, what do you need to model it? I don't mean in Ansys terms I mean what do you need to describe the problem?
    • Ammar676
      So I decided to simulate it on ANSYS Fluent. What I basically did is that I modelled two electrodes surrounded by an enclosure and then I defined the inlet, outlet, and the wall. I also initialized MHD and turned on the DPM. But, how can I add voltage to the electrode so I can view the transfer of charges?
      You'll probably need UDFs to assign a scalar electric field and then another UDF to add that force to the particles. Neither are going to be easy, and we (staff) can't help much with UDFs on here, others can: the limit of our advise is to read (very carefully) the UDF manual.
    • Ammar676
      Thanks a lot. You have helped me so much !
    • Ammar676
      , Is it possible to simulate a small airplane being propelled by ionic wind on ANSYS Fluent?!
      I gave it a thought and I think it would be a nightmare, donÔÇÖt you think?
      Pretty anything is possible, whether it's easy, sensible or physically realistic is an entirely different question. How do you intend to generate enough electron flow to move the mass?
    • Ammar676
      Well, the electron flow would be generated by a massive electric field difference between thin and thick electrodes so I think it wouldn't be an issue to propel an airplane that barely weighs 5 Kgs.
      I was wondering if I can simulate moving objects through ANSYS Fluent.
      My professor just wants to see any moving object pushed by ionic wind.
      It got even more worse, since I don't have any given information or an actual application. In fact, I have to come up with everything and I have been explaining to my professor that I cannot just make things up when I have a lot of unknowns.
      You can simulate objects moving, look at the moving deforming mesh, 6DOF. Why it moves may be much more complicated in your case.
    • 202070043
      Hi Ammar,
      I'm going to use Ansys to simulate the Ionic Wind as you did, is it possible to get your mail address for further information required, since you've done some work already and you may support me
      Looking at the logs Ammar676 hasn't been on for a while. The "@" symbol tags people so they may see the email notification. Whilst we do encourage collaboration we'd prefer to keep it on here so others can learn. A summary is sufficient!
    • 202070043
      @Robert Wool-house
      I'm using ANSYS Workbench and in another words, because of voltage potential between two electrodes, the air will ionize and charged particles would move, other researchers used COMSOL by using Electrostatic Field Module and Dilute Transfer Module to show the motion of charged particles in the gap as illustrated in attached picture, how to start with ANSYS Workbench to do this simulation? which modules on ANSYS to start with?
Viewing 17 reply threads
  • The topic ‘How to simulate Ionic Wind in ANSYS Workbench?’ is closed to new replies.
