April 25, 2024 at 5:55 am
Asahel Marinelarena-Diaz
SubscriberAs part of my research, I'm currently trying to simulate different kinds of objects (Washer, Plastic Cap, Nut, Bolt, etc) being pushed across a pipe system from Inlet to Outlet. I'm no expert withint Ansys Fluent, so far I've been able to create simulations where I place the object (stationary) and observe the velocity and pressure contours along with the velocity streamlines that are generated with an initial velocity as a boundary condition. But every simulation has been only with the object being static.
I would appreaciate if someone could guide me on the right approach for generating a dynamic simulation where the object moves alongside the fluid flow and reaches the outlet. I want to also evaluate the mass flow rate differential that this object may be causing to the system. (Approximate how much restriction/obstruction is the object generating).
Thank you in advance!
April 25, 2024 at 3:16 pm
Forum ModeratorOptions include moving deforming mesh (6DOF & collision detection), overset (also using 6DOF & collision detection) and possibly Rocky. None of those are going to be particularly easy, so review the effect on flow rate in a static case until you have a better idea of what/why you want to model.Â
April 29, 2024 at 7:14 pm
SubscriberCould you briefly explain how to setup those simulations? or provide a tutorial? I want to move forward to simulating a dynamic movement of the object across the fluid.
April 30, 2024 at 8:56 am
Forum ModeratorThere's the moving mesh tutorial in Fluent's Help using overset. You'd need to add in the contact (collision) detection, and that's covered in the UDF manual  https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v241/en/flu_udf/flu_udf_DynamicMeshDEFINE.html%23flu_udf_sec_define_contact
Otherwise, I'm not aware of examples and the cases I've had passing involvement with are all confidential.Â
- The topic ‘How to simulate an object moving by fluid flow inside a pipe system?’ is closed to new replies.
5939
1307
.png)
