March 23, 2023 at 1:23 pm
Naren B
SubscriberIm working on the fluid flow over a flat plate, in which the plate deforms like an S-shape.The external force is provided by the user,such that the plate deforms exactly as S-shape.how to mesh and simulate this profile.kindly help me out.
March 24, 2023 at 1:24 am
Subashni Ravichandran
Forum ModeratorHello Naren B
Are you trying to use Ansys Discovery for this simulation?
Please correct me if I'm wrong but are you trying to perform Fluid-Solid Interaction simulation here?ÂThis type of simulation is currently not possible in Discovery.
Although, if you are trying to perform a simple Fluid flow simulation over a bent plate, you will be able to do so.
Please go through our tutorials on Ansys Discovery to get an idea of how to use the tool.Â
Getting Started - Discovery Getting Started - Ansys Discovery Forum
April 18, 2023 at 9:09 am
Naren B
SubscriberHello SubashniÂ
Thanks for your reply
My requirement is to deform a flexible plate with prescribed input motion(I will instruct the way in which the plate deforms, for example: S-shape, C-shape, etc.,) and finding out the forces exerted on the plate in the presence of oncoming fluid flow(at some velocity)
kindly explain how to do this in Ansys-Fluent
April 18, 2023 at 9:18 am
Please post your question on Fluent in the Ansys Customer Portal.
This forum is exclusively for Ansys Discovery products.
- The topic ‘How to simulate a S-shaped motion over a flat plate’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- How to do the snap fit insertion FEA?
- Spaceclaim 2024 error FNE activation failed
- Ansys Discovery Crashing vGPU (Reproducible)
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
2778
965
841
599
591
