TAGGED: cfd-post, partcile-tracking, polyflow, polymer-extrusion
September 1, 2023 at 7:22 am
jishnu94.deu
SubscriberHi I wanted to show the flow of the material through the single extruder using ansys polyflow . In my cfd post I have options to show pressure, velocities , temperature etc. However i want to show how the material flows inside.
any idea how to do it ? is it by particle tracking ? if yes then can someone tell me how to do it
September 1, 2023 at 2:04 pm
Prashanth
Ansys EmployeeHi, you can use streamlines to see the flow pattern, starting from the inlet
- The topic ‘how to show the flow of the material in ansys polyflow’ is closed to new replies.
