TAGGED: ansys-autodyn, autodyn, equation-of-state, explicit-autodyn
April 29, 2024 at 8:55 pm
Shuan-Tai Yeh
SubscriberHi everyone,
I'm currently working on implementing an user defined EOS (Equation of State) using a lookup table similar to SESAME EOS in Autodyn. I've managed to modify the user-defined EOS in the
mdeos_user_1.f90file, but I'm unsure about how to include a table in the EOS. If anyone has any advice or suggestions, I would greatly appreciate your assistance.Thanks in advance!
April 30, 2024 at 9:50 pm
Chris Quan
Ansys EmployeeYou can refer to the Section 7.1. Subroutine MDSTR_USER_1 from Autodyn User's Subroutines Guide:
7.1. Subroutine MDSTR_USER_1 (ansys.com)
It has an example on how to use one-dimentional array in Autodyn User Subroutines. Below is the definition of array in this example:
! FOR EACH REAL INPUT PARAMETER, ASSIGN DATA ! ('name ' L, T,M,H, val, min,max,default,0,required) EQ%PAR(1)=PRMT (1,'Shear Modulus',-1,-2,1,0,ZERO,ZERO,BIG,ZERO ,0,1) ! THIS LINE MUST ALWAYS EXIST EQ%PAR(2)=PRMT (2,'EPS #1' , 0, 0,0,0,ZERO,ZERO,BIG,ZERO ,0,0) EQ%PAR(3)=PRMT (3,'EPS #2' , 0, 0,0,0,ZERO,ZERO,BIG,ZERO ,0,0) EQ%PAR(4)=PRMT (4,'EPS #3' , 0, 0,0,0,ZERO,ZERO,BIG,ZERO ,0,0) EQ%PAR(5)=PRMT (5,'YIELD #1' ,-1,-2,1,0,ZERO,ZERO,BIG,ZERO ,0,0) EQ%PAR(6)=PRMT (6,'YIELD #2' ,-1,-2,1,0,ZERO,ZERO,BIG,ZERO ,0,0) EQ%PAR(7)=PRMT (7,'YIELD #3' ,-1,-2,1,0,ZERO,ZERO,BIG,ZERO ,0,0)
Be aware that L, T, M, H in the Fortran statements above represent the exponent order of the unit Length, Time, Mass, and Temprature where a parameter has.
For example, shear modulus has the unit of Force/Area = Mass*Acceleration/Area.
If the system of unit is SI units of mks, the unit of shear modulus = Kg*m/s^2/m^2 = Kg*s^-2*m^-1. Thus, L=-1, T=-2, M=1, and H=0 in the parameter definition of shear modulus.In the user subroutine "mdeos_user_1.f90", you can
- Define the size of a table in the MODULE EOS_USER_1.
- Initialize the table in the SUBROUTINE INIT_EOS_USER_1.
- Assign values to the table in the SUBROUTINE SET_EOS_USER_1.
- The topic ‘How to setup user defined lookup table EOS in Autodyn?’ is closed to new replies.
5654
1885
1404
1303
