How to set up time in transient thermal analysis?
    • amando.gallardo
      Hello!
      I want to simulate a thermal cycling with time depending. Temperature goes: 20°C (12 hrs), 40°C (14 hrs), 80°C (6hrs), -40°C(6 hrs), 40°C(14 hrs) and 20°C(4 hrs).
      I know it might be defined through step controls, however I am not pretty sure about the right set up for time.
      Could you help me to clarify that please?
      Thank you!
      What is the Initial temperature of the parts? If it is 20C, then step 1 is irrelevant.nANSYS computes in seconds. The 40C is 14 hours = 50,400 seconds.nUnder Analysis Settings, change Auto Time Stepping to On.nInitial Time Step = 500 seconds or about 1%nMinimum Time Step = 50 seconds or about 0.1%nMaximum Time Step = 5000 seconds or about 10%nUse a similar pattern for the other steps.n
    • amando.gallardo
      Hello Peter!nYes, the initial temp of the parts if 20?C.nUnderstood, that was my doubt, it is clear now nThank you so much, I really appreciate your help!n
    • amando.gallardo
      HI Peter, I tried to set up the time step controls as you suggest, however I get an error: Invalid maximum time stepnHow can I to overcome this issue?n:Dn
Viewing 5 reply threads
  • The topic ‘How to set up time in transient thermal analysis?’ is closed to new replies.
