Electronics
Electronics
How to set up the time for analysis with the presence of variables?
    • Juefei Li
      Hi community. I'm recently doing simulation using Ansys EM 2020R2, and I can't seem to set the time for analysis right. To be more specific, I want to include the variable "n" which represents angular velocity. Its unit is "rpm". If I type its value "200", I can absolutely get the right result (see in the first two pictures).
      But if I type "n", things will go wrong(like in the last two pictures)... How can I solve this problem?
    • HDLI
      Hello Juefei,
            Please use "n/1rpm" to get 200 because n is a variable with an unit.
      HDLI
    • Juefei Li
      Hi HDLI~ I've tried your method, and it turns out that an additional "*1s" is needed to get the right unit. Thanks for your help, I've been stucked here for a long time.
  • The topic ‘How to set up the time for analysis with the presence of variables?’ is closed to new replies.
