February 21, 2024 at 2:45 pm
Mepal
SubscriberHello everyone,
I have a straightforward question regarding Fluent meshing. I've attempted to establish input parameters for mesh size. In regular Ansys meshing, this can be done easily by clicking on the small square, which then displays a "P" symbol.
However, I've encountered difficulties trying to achieve the same in Fluent meshing. Does anyone have any suggestions for resolving this issue?
Thank you in advance for your assistance.Best regards,
February 22, 2024 at 8:37 am
V.P
Ansys EmployeeHi,
Can you check out the link to user guide which will help you with setting up parameters
3.11. Using a Journal File to Parameterize Fluent Meshing Inputs (ansys.com)
March 26, 2024 at 7:41 pm
DMG2066
SubscriberHi @Mepal , just wondering if you managed to find a solution to this issue? Im also having difficulty figuring out how to paramaterise in fluent meshing. Thank you.Â
- The topic ‘How to set up the input and parameters in Fluent meshing’ is closed to new replies.
