How to set up material properties of EPE foam in LS-DYNA?
    • water5726water5726
      Dear team,
      I want to simulate notebook drop in LS-DYNA and I use EPE foam to absorb impact force.
      I have studied papers on EPE foam simulation and it seems that mat57, mat63, and mat83 can be used.
      Which material card is better for EPE foam?
      Thanks!
    • Ram Gopisetti
      Hi @Water, mat57-- for low density foam ,mat63-- crushable foams (as in flower foams) ,mat83-- for low and high foams ( seat foams and cushion) , based on these, take the material model as described in "Article" and see if you can replicate the results first and then adapt other mat models.
      Cheers, Ram
  • The topic ‘How to set up material properties of EPE foam in LS-DYNA?’ is closed to new replies.
