April 2, 2025 at 4:13 pm
Tim T
SubscriberI use S-ALE for solution calculation. I want to set up some monitoring points that move along with the fluid to monitor the fluid velocity. I would like to learn the specific steps for setting up these monitoring points.
April 3, 2025 at 12:40 pm
Alex R.
Ansys EmployeeHello Tim,
You will need to define *DATABASE_TRACER_ALE. If a tracer is moving with the fluid the TRACK flag should be set to 0.
From manual:Save a history of either a material point or a spatial point using tracer particles
into an ASCII file: traleh. This history includes positions, velocities, and stress and other
user-specified element history variables. The option *DATABASE_TRHIST must be active.
This keyword is only to be used with ALE problems.Please let me know how it goes,
Thank you,
Alex
2778
965
841
599
591
