August 27, 2024 at 4:28 pm
zzhang868
SubscriberI use "Scripting" to write Python code that adjusts the "Analysis Settings" to set up 100 time steps. However, whenever it runs through a few steps (around 10, for example) to update the settings, the machine crashes. I'm using a CPU with 240 cores (10 nodes, each with 24 cores). I'm wondering if there's a way to run the scripting without issues. Should I modify any settings to ensure the scripting runs smoothly? Thank you so much!
August 28, 2024 at 1:32 pm
mrife
Ansys EmployeeHi
Can you define what you mean by 'machine crashing'. Do you really mean the hardware crashes i.e. powers off or reboots? Or that the application crashes. An actual hardware crash would be odd and would look at whether the CPU or RAM are over-clocked. This could cause either to run hot and the heat dissapation capacity of the compute node to be overwhelmed.
If you really mean the application can you post any warnings and errors found in the Solution Output.
MIke
August 28, 2024 at 2:54 pm
zzhang868
SubscriberHi Mike, when I mention “crash,” I am referring to a “reboot” situation. Specifically, the “Mechanical” page first becomes unresponsive and then suddenly closes. I am currently using a server instead of a laptop.Do you have any suggestions as to why this might be happening? Thank you!
August 28, 2024 at 4:20 pm
mrife
Ansys EmployeeOk - well as I said first investigate the hardware and see if either the CPU or RAM are overclocked. If there is a thermal management tool available see if it has a log. In the meantime post any warnings and errors that are in the Mechanical Solution Information object.
August 28, 2024 at 8:48 pm
zzhang868
Subscriber*** A fatal error has occurred within AnsysWBU.exe and it must be closed...***
/usr/local/pace-apps/manual/packages/ansys/2023R2/v232/aisol/.workbench: line 271: 3240 Aborted $Pgm $Args
This is what error I got. Do you have any suggestions? Thanks a lot!
