November 24, 2020 at 9:40 am
User9
SubscriberI am using Discrete Phase model for GAS COOLER. Basically flue gas is being cooled by sprinkling water from nozzles in a chamber. For the above purpose there are array of Nozzles. Around 200 nozzles are to be defined in Discrete Phase Model setup. Defining individually 200 nozzles through their X Y Z coordinates would take huge time. I cannot found a way to input a array of nozzles.nnIs there a way to set up a array of nozzles in Discrete Phase model in Fluent?.Thankyou in advance.n -
November 24, 2020 at 10:30 am
Forum ModeratorYou can copy injections, which makes it a bit simpler. In the tree you can also export the injection, the format's a bit messy but if you know what the GUI setting was you'll be able to find the numbers and then manually adjust each injection (not ideal) or, finally, use a TUI journal to create the injections. I'd favour the latter approach as once you have the syntax you can create a journal very quickly. n
- The topic ‘How to set up array of nozzles in Discrete Phase model in ANSYS Fluent?’ is closed to new replies.
Ansys Innovation Space
1283
1107
1068
983
