LS Dyna
LS Dyna
How to set the specified several ELEMENT as monitoring points?
    • Tim T
      I want to set several element as monitoring points and check the stress variation curves of these element after the calculation is completed. I would like to know the method of setting monitoring points.
    • ilker.kurtoglu
      Hi Tim,
      You can use *DATABASE_ELOUT together with *DATABASE_HISTORY_{ELEMENT_TYPE} for this purpose. I assume that you are performing simulation with classical lagrangian approach.
      İlker Kurtoğlu
      • Tim T
        I used the keywords *DATABASE_ELOUT and *DATABASE_HISTORY_SOLID to monitor ELEMENT, but there was no data output in ASCII.
