TAGGED: define-source, Lumerical-FDTD, photonics, source-setting
September 20, 2022 at 8:37 am
JING PENG
SubscriberHi Everyone,
Right now, I want to set up the orbital angular momentum (OAM) modes of the incident light in Lumerical FDTD. Does anyone know how to set the OAM mode of incident light?
It looks like that we can't set up this in the software itself, but we might be able to set it up in the lumerical script section. Below is an example of setting some parameters of the incident light, which I got online. It might a hint/reference to you.
Really hope someone can tackle this issue. Thanks.
# scriptfile:usr_custom_source.lsf# define position vectorsx=linspace(-10e-6,10e-6,401);y=linspace(-10e-6,10e-6,401);z=0; #this is z z-normal sourceX=meshgridx(x,y);Y=meshgridx(x,y);lambda0=0.5e-6;f=c/lambda0;w=2*pi*f;k=2*pi/lambda0;#calculate k-space field profilesNA=0.2;kx=linspace(-k,k,200);ky=linspace(-k,k,200);Kx=meshgridx(kx,ky);Ky=meshgridy(kx,ky);phi=atan2(Ky,Kx);theta=real(acos(sqrt(1-Kx^2/k^2-Ky^2/k^2)));envelope=exp(-0.5*(Kx^2+Ky^2)/(NA*k)^2);Exk=cos(phi)*cos(theta)*envelope;Eyk=sin(phi)*cos(theta)*envelope;Ezk=sin(theta)*envelope;Ex=-1i*czt(Exk,kx,ky,x,y);Ey=-1i*czt(Eyk,kx,ky,x,y);Ez=-1i*czt(Ezk,kx,ky,x,y);Hxk=-sqrt(eps0/mu0)*sin(phi)*envelope;Hyk=sqrt(eps0/mu0)*cos(phi)*envelope;Hx=-1i*czt(Hxk,kx,ky,x,y);Hy=-1i*czt(Hyk,kx,ky,x,y);Hz=0*Ex;# sacle fild so E^2=1E2=abs(Ex)^2+abs(Ey)^2+abs(Ez)^2;scaleFactor=sqrt(max(E2));Ex=Ex/scaleFactor;Ey=Ey/scaleFactor;Ez=Ez/scaleFactor;Hx=Hx/scaleFactor;Hy=Hy/scaleFactor;Hz=Hz/scaleFactor;# package field data into the EM fields datasetEM=rectilineardataset("EM fields",x,y,z);EM.addparameter("lambda",c/f,"f",f);EM.addattribute("E",Ex,Ey,Ez);EM.addattribute("H",Hx,Hy,Hz);# save dataset to .mat filematlabsave("import_data.mat",EM); -
September 20, 2022 at 3:57 pm
Guilin Sun
Ansys EmployeeThis question has been replied here 请问和求教Lumerical FDTD 中如何设置入射光的光子轨道角动量OAM的问题
Please note that there are limited number of standard sources in FDTD. However, with import, you can set up whatever the source you want.
June 8, 2023 at 11:53 am
uzmayaqoob1960
SubscriberDEar Jing have u got any guidance how to impinge OAM source in Lumerical?
If yes then plz let me know too.
June 8, 2023 at 2:29 pm
Guilin Sun
Ansys EmployeeYou have analytical solution for the OAM source. Please refer to this example https://optics.ansys.com/hc/en-us/articles/360034383054-Using-an-equation-to-define-the-spatial-field-profile-of-a-source-in-FDTD
- The topic ‘How to set the OAM parameters of incident light in Lumerical FDTD?’ is closed to new replies.
