October 27, 2021 at 9:02 am
denny9696
SubscriberOctober 27, 2021 at 7:14 pmHDLI
For the questions, could you clarify what the frequencies are for? It seems to me that 10kHz is for switching frequency of PWM, and 1kHz is for fundamental frequency of current.
If Yes, 10kHz would be entered in SVPWM block and 1kHz need to be converted to speed reference in const2, rpm = 120*f/2p. Thanks.
HDLI
October 30, 2021 at 10:23 amdenny9696
i wanna like dsp (Digital Signal Processor)
set current loop(inner loop) 10k hz which i can use SVPWM block
but the speed loop(out loop) set 1khz
sorry i don't understand you mean set const2
must to set pi controller sampling time?
April 27, 2022 at 2:07 pmMeroz
Subscriberi am trying to build my pmsm model with foc closed loop. thus, i would like to know how did you manage to get flux_d and flux_q outputs from your maxwell model. does the term dcp_q stand for the compensation term? if so how can we have our Lq from maxwell.
May 23, 2022 at 6:35 amdenny9696
Subscriberhi
i use flux estimator to find flux dq then dot speed or u can set the LUT
u can write c-model code build of them
Viewing 4 reply threads- The topic ‘how to set inner loop and outer loop frequency in simplorer?’ is closed to new replies.
Innovation SpaceTrending discussions- Three-Phase Voltage Imbalances in dual stator electric generator
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
Top Contributors-
4597
1495
1386
1209
