March 18, 2024 at 12:08 pm
March 18, 2024 at 6:14 pm
GWANG
Ansys EmployeeHi pengzheng97,
Thank you for the post. Do you want to import an optical source or an electrical source? To import an electrical source is relatively easier, and we have elements like Piecewise import to import arbitrary electrical source. To import an optical source, you may refer to this page to do so: https://optics.ansys.com/hc/en-us/articles/4412906407955-Arbitrary-Waveform-Generators-from-File-for-INTERCONNECT. You can also use a scripted element to generate an optical source and use it in the circuit design as well.Â
March 19, 2024 at 1:30 am
pengzheng97
SubscriberHi, thanks for your reply, it solved my problem, thank you !????
- The topic ‘How to set given sequence as source sequence in INTERCONNECT’ is closed to new replies.
1495
1386
1209
