October 18, 2024 at 8:23 am
yasmine.sichaib
SubscriberHello,
I would like to know how to switch the global coordinate system in ansys Maxwell from cartesian to cylindrical. I need to make some force calculation using the field calculator and I need to do it respectively to z, r and theta.
Thanks
October 21, 2024 at 3:10 pm
NA
Ansys EmployeeHello Yasmine,
By default the calculations in the Global Coordinate System are cartesian. In fields calculator you can change that by selecting “to cylindrical” from the “X Form” drop down list in the Vector column. This operation turns ScalarX, ScalarY and ScalarZ operations into ScalarR, ScalarPhi and ScalarZ values. So for example if you want to calculate the lumped force in the R direction of object “Box”, you would do the following in fields calculator:
Select Quantity > Volume force density
From column “Vector”, select “X Form” > To Cylindrical > In the pop-up window select “ok” without adding offset
From column “Vector”, select “Scal?” > ScalX (ScalX now represents ScalR in cylindrical)
Select geometry “Box” and integrate the volume force density in the R direction over the volume of the box.
Kind regards,
Niki
5249
1859
1387
1255
