September 24, 2024 at 1:31 pm
Md_Salem
SubscriberHello everyone,
I am using Design modeler to construct an optimization problem
I defined two dependent parameters (H8,V6) in the Design modeler as shown in the next two pictures as well as independent parameters
my question here is, how do I set some unequility constraints on the dependent parameter given that they don't appear as parameters in the optimization section since they are dependent on other parameters?
September 25, 2024 at 2:44 pm
Gary_S
Ansys EmployeeHello
Here is one idea:ÂIn DM, you can create "dummy parameters"  then define geometry based on that dummy parameter.Â
Then in a DOE optimization, you can assign a range to that dummy parameter.
ÂÂAnother idea may be this:Â
This will work only for a  Direct Optimization type, not say a Response Surface.
 It is possible to define a bound that is say an equation based on other values. It is done in the Parameter Relationships section.Â
September 26, 2024 at 7:42 am
Md_Salem
SubscriberHello,
The attached picture couldn't be loaded properly.
Would you reload it again ?
Regards
5769
