September 23, 2024 at 5:16 am
s.hamade
SubscriberHello, I am trying to simulate the delamination between two layers in a laminate.I already created the interface layer in ACP.ÂAlso you find attached:- the mesh of curved laminate extracted from ACP- the interface layer in red (with crack front)- the interface delamination surface I am trying to select- the worksheet i used to create it- the interface delamination details window, that i am trying to complete.ÂWhat is missing in the detail window of interface delamination is to select:ÂÂ- the source and target faces of the interface layer.ÂÂI tried to create a node named selection of the interface layer using worksheet but:Â1- this node name selection contains BOTH source and target nodes.ÂHow can select only source Or only target ? Also how can I do to fill the details window ?ÂPS: In the option Generation Method of the scope paragraph, I can't find the Pre-Generated interface as in the delamination tutorial of ACP advanced!ÂÂThank you for your contributionÂSami -
September 24, 2024 at 11:27 am
s.hamade
SubscriberHi all, I’d appreciate any help on this case. @ANSYS support or any experienced contributors, your input would be valuable. Thank you!
October 3, 2024 at 1:22 pm
Ashish Khemka
Forum ModeratorHi,
Please see if the following links help:
5.5.7.3. Interface Delamination and Ansys Composite PrepPost (ACP)
2.1.10.5. Interface Layer Properties (ansys.com)
Ashish Khemka
1891
1419
