October 15, 2020 at 7:44 pm
snipesc
SubscriberThis is a hyoid apparatus from a bat. I need to create a named selection which will require me to select all the faces I have circled in the photo below. However when I use the box select, it selects the faces on the other side of the hyoid body, too. I only want the faces which are facing me in the photo. Hope that makes sense. I started to select each individual faces, but it would take hours. There has to be an easier way! Anyone?
October 15, 2020 at 7:44 pmsnipesc
SubscriberFinally got a model to mesh! nJuly 7, 2023 at 12:34 pmMikhail Narsai
SubscriberDid you ever find a way to perform this one-sided box selection?July 8, 2023 at 1:45 ampeteroznewman
SubscriberMikhail, if you double click on one facet, a selection of adjacent facets are automatically selected and a slider bar pops up. Grab the bar on the slider and pull it up to increase the number of facets that are selected. The boundary is automatically selected based on the angle between facets.
July 10, 2023 at 7:46 amMikhail Narsai
SubscriberThank you!!Viewing 4 reply threads- The topic ‘How to select only one side of complex geometry using box in Mechanical?’ is closed to new replies.
