how to select individual bodies during optimization ?
    • Md_Salem
      Hello everyone,
      I am doing optimization to select the optimum number of Piezoelectric patches on a plate using harmonic analysis at target natural frequency. After the modal analysis is done in the workbench, I use the next APDL code.
      /post1
      set,first
      *GET,Fd1,MODE,1,FREQ
      x11=Fd1-2.5
      x12=Fd1+2.5
      FINISH
      /SOLU
      ANTYPE,harmonic
      HROPT,FULL
      HROUT,ON
      LUMPM,0
      ESEL,S,ENAME,,226    ! Select all the piezo elements for all piezo patches.
      NSEL,R,LOC,Z,0.001    ! Select the upper surface of them.
      D,ALL,VOLT,ARG1        ! Apply the load ARG1 (voltage).
      ALLSEL
      ESEL,S,ENAME,,226
      NSEL,R,LOC,Z,0
      D,ALL,VOLT,0
      ALLSEL
      EQSLV, ,0,
      PSTRES,0
      HARFRQ,x11,x12
      NSUBST,100
      KBC,1
      DMPRAT,8e-5
      SOLVE
      FINISH
      The Piezo patches are added to the design modeler as an array where the number of coppies is parametrized.
      How can I select the piezo patches individually to apply different voltage loads instead of selecting them all as shown in the upper code?
      Regards
    • ashish.khemka
      One suggestion - once you select all the SOLID226 elements then you can reselct them based on the locations, if that is a convenient option.
      Ashish Khemka
    • Md_Salem
      hello,
      The problem is that the number of generated bodies is large, so the locations are parametrized and generated according to the optimizer.
      Regards
  • The topic ‘how to select individual bodies during optimization ?’ is closed to new replies.
