Ansys Products
Ansys Products
How to save an ANSYS workbrench project withe the ability to open and to run it from any computer?
    • nastyashustic
      I have a problem with project .wbpj. In project I have external midel and data and results of calculation, and then I move with project to another computer and another disk, all connections and results doesnt work (yellow lightning ? near solving moduls).nHow to save project with subsequent opening from another place?n
      Array If you Archive the project and then move it the links should re-form once you extract the archive on the new computer. It's an option under File in WB. In the newer releases you can open an archive, older versions require the extract archive option in File. n
  • The topic ‘How to save an ANSYS workbrench project withe the ability to open and to run it from any computer?’ is closed to new replies.
